The Asian Commercial Sex Scene
Go Back   The Asian Commercial Sex Scene > For stuff you can't discuss with your Facebook Account > Sexual Health Issues
Notices
Sexual Health Issues If you need medical advice regarding your sexual health, ask Dr Tan. We are honored to have an In House Doctor who is here to help.
User Tag List
Reply
Thread Tools
  #1831
Old 09-01-2022, 08:18 AM
Darknite Darknite is offline
Samster
Quoted: 2 Post(s)
My Reputation: Points: 585 / Power: 15
Darknite is a name known to allDarknite is a name known to allDarknite is a name known to allDarknite is a name known to allDarknite is a name known to allDarknite is a name known to all
Re: Circumcision: my experience
Hi Dr Tan
i used to suffer from very very bad phimosis without realising it. I only realised it after my days in poly, which then i started to do my own stretching exercise (the amount of pain, tears, blood and almost paraphimosis is so scary), but i ultimately managed to pull back my foreskin.
however i noted that my foreskin would form a ring around the head, and it is tight, preventing much "expansion".. i also noted that i have a very short frenulum, which is also quite a issue.
I do know that i had phimosis, but if i go to a doctor now, would i be able to claim from my insurer since i "theoretically" can pull back the fore skin?
also should i go for circumcision?
  #1832
Old 10-01-2022, 09:10 AM
DoctorTan DoctorTan is offline
Quoted: 45 Post(s)
My Reputation: Points: 620 / Power: 11
DoctorTan is a name known to allDoctorTan is a name known to allDoctorTan is a name known to allDoctorTan is a name known to allDoctorTan is a name known to allDoctorTan is a name known to all
Quote:
Originally Posted by Darknite View Post
Hi Dr Tan
Hi. Technically you still have phimosis even though you can now expose the head. The tight ring and short frenulum could both negatively affect your erections. Also, this actually puts you at higher risk of paraphimosis. And you are right, this is quite scary. In fact, it is a medical emergency.
I have done many circumcisions covered by insurance. They honestly do not care if you are able to pull your skin back or not. They just need your Doctor to certify that it is medically necessary.
Yes. You should absolutely go for a circumcision. It will solve all your problems. As you can see from the experience of many here, the circumcision process is not as scary as you think it is.
  #1833
Old 11-01-2022, 09:47 PM
sigueroa sigueroa is offline
Samster
Quoted: 2 Post(s)
My Reputation: Points: 24 / Power: 0
sigueroa deserves a Tiger! - He's a Good Guy
Hi Dr Tan, Signed up a new account to get your advice. I've benefited a lot from all your sharing!
I've been having these small foreskin cuts, not on the frenulum. These cuts came up more frequently over the past 2 months, sometimes at the same area, sometimes at different area. I am getting a little concerned as this affects my sex life. This cut appears mainly after erection when I pull my foreskin back - like an overstretched of the foreskin.
I am still able to retract my foreskin back, though it seems "tighter" than last time.
I've been to my GP about 2 weeks back who gave me antifungal and antibiotics cream - I applied for one week, seems in control until when I was planning to have sex and tried to stretch my foreskin, and the cuts appeared again. These 2 cuts healed after 2-3days, now every time I shower I also try to stretch the skin. And sometimes 1-2 small cuts appear at other areas too. My foreskin gets itchy sometimes too.
Today, I went to visit a urologist - he shared the skin looks a bit "white" and since I've tried so many creams and it comes back, he recommended me circumcision.
For now, the routine I'm adopting is:
1. Ensure my penis/foreskin is always dry.
2. Apply Vaseline whenever I can throughout the day.
3. Before bed, apply the antifungal + antibiotic cream, then with Vaseline.
Can I get your advice if this is okay? Or should I just go for circumcision?
Thank you so much Dr.
  #1834
Old 12-01-2022, 07:39 AM
Quoted: 45 Post(s)
Hi,
Have you checked your blood sugar? These could be symptoms of Diabetes. If you are Diabetic you need to get that under control.
More likely, your symptoms are due to Balanitis Xerotica Obliterans (BXO). In which case you will need a circumcision. BXO will progress no matter what you do (strong steroid creams may delay the progression). The hardening might even spread to your urethra after which surgeries get really complicated. BXO also increases the risk of skin cancer.
So I have to say I agree with your Urologist. You need a circumcision. Send the skin for histological examination to determine if you truly have BXO or not.
  #1835
Old 12-01-2022, 10:41 AM
Samster
Quoted: 2 Post(s)
Quote:
Originally Posted by DoctorTan View Post
Hi,
Hi Dr Tan,
Thank you for your quick response I truly appreciate it.
I did not check if I am diabetic, but the last I did my full body checkup few months ago, I was okay.
I am not comfortable with the use of steroids, however in the meantime, are the steps I provided enough for the management of BXO? And what are the signs/symptoms I should take note before confirming that circumcision is necessary?
On histological examination, should I consult my urologist to do so?
Honestly speaking, I know it seems like the solution points to circumcision, but I was really hoping to see how I can best manage and control it first. Also due to my work commitment, the earliest I can do the surgery is early March.
  #1836
Old 26-01-2022, 10:21 AM
hornie's Avatar
hornie hornie is offline
Samster
Quoted: 31 Post(s)
My Reputation: Points: 608 / Power: 20
hornie is a name known to allhornie is a name known to allhornie is a name known to allhornie is a name known to allhornie is a name known to allhornie is a name known to all
Just go for a circumcision dude. Your quality of life will improve drastically.
Hi Dr Tan,
  #1837
Old 24-03-2022, 02:56 AM
AdrusBarba AdrusBarba is offline
Samster (M)
Quoted: 0 Post(s)
My Reputation: Points: 20 / Power: 0
AdrusBarba deserves a Tiger! - He's a Good Guy
Quote:
Originally Posted by Dekachin View Post
Great post... but I still prefer my uncircumsized cock...
You may not know the benefits You are free to many infections.
  #1838
Old 26-03-2022, 04:04 AM
loveletters loveletters is offline
Samster
Quoted: 26 Post(s)
My Reputation: Points: 197 / Power: 12
loveletters is a Helpful and Caring Samsterloveletters is a Helpful and Caring Samster
Hi Dr Tan I am diabetes type 2 is it ok to go for circumcision?
  #1839
Old 28-03-2022, 04:47 PM
Quoted: 45 Post(s)
Quote:
Yes. In fact I do a lot of circumcisions for people with Diabetes.
Diabetes increases the risk of fungal balanitis and can even lead to phimosis.
Some medicines used to treat Diabetes (the ones that make you urinate out sugar) also greatly increases the risk of balanitis.
Diabetes increases your risk of a wound infection and also can cause delayed healing. Because of this, I do NOT recommend a ShangRing procedure or people with Diabetes. Personally I like to do the laser method. I find that the healing is fastest and risk of infection the lowest.
Please do see a Doctor experienced in doing circumcision for patients with Diabetes. Also please ensure your blood sugar is as well controlled as possible before and after the surgery.
  #1840
Old 30-03-2022, 03:31 AM
Samster
Quoted: 26 Post(s)
Thanks for the advice.
  #1841
Old 26-08-2022, 07:14 PM
Ghrow Ghrow is offline
Samster
Quoted: 2 Post(s)
My Reputation: Points: 53 / Power: 7
Ghrow deserves a Tiger! - He's a Good Guy
If go polyclinic and get referral letter to public hospital what's the cost ah? Is it fully covered by Medisave? I also have integrated shield insurance plan - can use to cover if not fully covered by Medisave?
  #1842
Old 07-09-2022, 02:09 PM
Olofmeister Olofmeister is offline
Samster
Quoted: 77 Post(s)
My Reputation: Points: 411 / Power: 6
Olofmeister is a living Saint! - you won't find betterOlofmeister is a living Saint! - you won't find betterOlofmeister is a living Saint! - you won't find betterOlofmeister is a living Saint! - you won't find betterOlofmeister is a living Saint! - you won't find better
has anyone done with Dr Tan at his clinic? I have been contemplating for years.
  #1843
Old 08-09-2022, 05:21 PM
Quoted: 45 Post(s)
https://www.mewatch.sg/watch/Circumc...-Health-315638
  #1844
Old 10-09-2022, 12:02 PM
rogerbear rogerbear is offline
Samster
Quoted: 91 Post(s)
My Reputation: Points: 342 / Power: 2
rogerbear is one of the Best!rogerbear is one of the Best!rogerbear is one of the Best!rogerbear is one of the Best!
I also have phimosis but also can slide back just that it gets tight around the head.
Is there anyway to get it insured under hospital plan or is it like accident plan that kind? Pls do give advice Dr tan. Ty
  #1845
Old 12-09-2022, 11:56 AM
Quoted: 45 Post(s)
This something best answered by your insurance agent. It will differ between policies.
All I can say is that many of my patients have successfully claimed the cost of their circumcision surgeries from their hospitalisation plans.
What I actually do is to refer my patients back to their own agents or an insurance claims specialist first. Get all the paperwork done swee swee before proceeding with the surgery.
Even better we get a payment guarantee upfront. In this way we not scared that the insurance will refuse to pay.
Advert Space Available
Bypass censorship with https://1.1.1.1
Cloudflare 1.1.1.1
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.10
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copywrong © Samuel Leong 2006 ~ 2023 ph
